Re: AdaptDBMC - Luma/Fade/Blue自适应debanding脚本(公测,各种待优化)
2011-12-16 14:45
其实1/3为单位floor的话精度也差不多足够了,反正x factor后还是会取整,实际上用到的精度可能差不多就是1/3左右……不过其实目前速度影响最大的估计还是在MVtools里,f3kdb好快好快的-v-
histamine
2011-12-16 14:56
--- AdaptDBMC_beta.avsi 2011-12-15 05:49:50.000000000 +0800 +++ AdaptDBMC_beta_Mod.avsi 2011-12-16 15:19:43.000000000 +0800 @@ -128,16 +128,41 @@ ### Mix all factors and calculate final factor of strength global strFact = "( " + AdaptLuma + " * ( 1 + " + AdaptFade + " ) * ( 1 + " + AdaptBlue + " ) )" -global f3kdb_eval = "f3kdb( Y=int("+String(Y)+"*"+strFact+ -\ "), Cb=int("+String(Cb)+"*"+strFact+ -\ "), Cr=int("+String(Cr)+"*"+strFact+ -\ "), ditherY=int("+String(ditherY)+"*"+strFact+ -\ "), ditherC=int("+String(ditherC)+"*"+strFact+ +global f3kdb_eval = "f3kdb( Y=int("+String(Y)+"*f3kdb_rfact"+ +\ "), Cb=int("+String(Cb)+"*f3kdb_rfact"+ +\ "), Cr=int("+String(Cr)+"*f3kdb_rfact"+ +\ "), ditherY=int("+String(ditherY)+"*f3kdb_rfact"+ +\ "), ditherC=int("+String(ditherC)+"*f3kdb_rfact"+ \ ( Defined(f3k_param) ? "), "+f3k_param+" )" -\ : ") )" ) +\ : ") )" ) + +\ ( Info ? """.Subtitle("Real Final factor: "+String(f3kdb_rfact), x = 8, y = 28)""" : "") -Info ? ScriptClip( f3kdb_eval+""".Subtitle( "Final factor: "+String( Eval(strFact) ), x=8, y=8 ).Subtitle( "Luma adaptive factor: "+String( Eval(AdaptLuma) ), x=8, y=38 ).Subtitle( "Fade adaptive factor: "+String( 1+Eval(AdaptFade) ), x=8, y=58 ).Subtitle( "Blue adaptive factor: "+String( 1+Eval(AdaptBlue) ), x=8, y=78 ).Subtitle( "Frame complexity: "+String( Eval(c_Complex) ), x=8, y=108 )""" ) -\ : ScriptClip( f3kdb_eval ) +global f3kdb_rfact = 1.00 +global f3kdb1 = Eval(f3kdb_eval) + +global f3kdb_rfact = 1.33 +global f3kdb2 = Eval(f3kdb_eval) + +global f3kdb_rfact = 1.67 +global f3kdb3 = Eval(f3kdb_eval) + +global f3kdb_rfact = 2.00 +global f3kdb4 = Eval(f3kdb_eval) + +global f3kdb_rfact = 2.33 +global f3kdb5 = Eval(f3kdb_eval) + +global f3kdb_rfact = 2.66 +global f3kdb6 = Eval(f3kdb_eval) + +global f3kdb_rfact = 3.00 +global f3kdb7 = Eval(f3kdb_eval) + +global f3kdb_eval2 = """vStrFact = Eval(strFact)""" + chr(13)+"""f3kdbRet = (vStrFact < 1.33) ? f3kdb1:(vStrFact < 1.66) ? f3kdb2:(vStrFact < 2.0) ? f3kdb3:(vStrFact < 2.33) ? f3kdb4:(vStrFact < 2.66) ? f3kdb5: (vStrFact < 3) ? f3kdb6 : f3kdb7""" +eClip = last +sClip = BlankClip(f3kdb1) +Info ? ScriptClip( f3kdb_eval2+chr(13)+"""f3kdbRet.Subtitle( "Final factor: "+String( Eval(strFact) ), x=8, y=8 ).Subtitle( "Luma adaptive factor: "+String( Eval(AdaptLuma) ), x=8, y=58 ).Subtitle( "Fade adaptive factor: "+String( 1+Eval(AdaptFade) ), x=8, y=78 ).Subtitle( "Blue adaptive factor: "+String( 1+Eval(AdaptBlue) ), x=8, y=98 ).Subtitle( "Frame complexity: "+String( Eval(c_Complex) ), x=8, y=128 )""" ) +\ : Eval("""ScriptClip(sClip, "Eval(f3kdbRet)")"""+chr(13)+"""FrameEvaluate(eClip, f3kdb_eval2 )""") return SelectEvery( 1 + radius * 2, radius) }
info=false时支持16bit输出
发现写错了,请不要用
修正:
=> SCTri(ScriptClip(sClip, "f3kdbRet"),FrameEvaluate(eClip, f3kdb_eval2 ))
上次由 histamine 在 2011-12-16 17:15,总共编辑 6 次。
2011-12-16 15:01
晚上回去放个能支持16bit输入/输出的版本~
histamine
2011-12-16 17:07
写了个插件用来处理不同分辨率情况下,ScriptClip和FrameEvaluate组合使用的情况
LoadCPlugin("ScriptTrick.dll") XXXSource() feClip = FrameEvaluate( last.Spline36Resize(1280,720).ColorYUV(gain_y=50), "Text = String(AverageLuma)") scClip = ScriptClip( last.Spline36Resize(1920,1080), "Subtitle(Text).Subtitle(String(AverageLuma),y=20)") SCTri(scClip,EvalClip=feClip)
每次GetFrame时先获取feClip第n帧,再获取并返回scClip的第n帧
ScriptTrick20111216.7z
(58.66 KiB) 下载 84 次
histamine
2011-12-17 7:13
diff
&#9658; 显示内容
avsi:
&#9658; 显示内容
Speedup
update:
支持手动指定用来计算Final Factor的Clip(mvp参数),从而可以通过指定f3k_param参数实现支持16bit输入输出
并且可以通过降低mvp分辨率提高运动补偿速度(但会影响Frame complexity和Fade adaptive factor的计算)
&#9658; 显示内容
