Re: GrainFactoryLite v1.1 - 16bit的Luma自适应噪点生成滤镜
AvsPmod_v2.2.1.1-laa(binary).rar
(12.94 KiB) 下载 114 次
Try to replace AvsPmod.exe using the binary attached above, and add SetMemoryMax(1536) to see if it helps.
The official build of AvsPmod.exe does not compiled with LARGEADDRESSAWARE flag, and thus can only use 2GB memory, so setting memory max too high will cause crash, while setting it too low will make the 16-bit processing failure for lack of memory. I switched on the LARGEADDRESSAWARE flag and made AvsPmod.exe able to use 4GB memory on x64 Win OS or 3GB on x86 Win OS ( x86 systems may need special configurations, which should be easily found on Google ).
PS: But it is really weird if it crashes on 1280x720 while works fine on 1440x810. I'll look into it to see if there's any other bugs.
Hoodlum
Nope, it didn't help.
And sorry, I forgot to mention that this avs:
FFVideoSource("E:\DenpaTeki\OVA1.mkv")
SplineResize(1280,720).AddBorders(0,0,1920-1280,0).GrainFL().Crop(0,0,1280-1920,0)
works fine.
I also tried placing FrameCache between resize and GrainFL() (as well as before resize) to see if it helps, but it doesn't.
Well, crashes on other tools, seems to have nothing to do with AvsP. I'll look into GrainFL. It is most possibly that I made some stupid mistakes in the script....
I found the reason. It is a bug in "Dither_resize16". It always crashes when resizing a 1068x600 clip to 1280x720 using Bicubic kernel. Unfortunately, if GrainFL's "g*size" is set to 1.2 and the source clip is 1280x720, this buggy scaling operation will be applied to the GrainLayer clip.
I have reported this bug to cretindesalpes. Just wait for his update of dither pack. For now, using values other than 1.2 for "g*size" when source clip is 1280x720 can solve this problem, say, g2size=1.21. Or you can use v1.12.0 or older versions of dither.dll, which do not have this issue.
Hoodlum
Got it. Thank you.
