hokop16436@xhypm.com
动态帧率的电影怎么搞?想要二次压制,能否转换成固定帧率(只有DVD压制源的老片《鬼子来了》)
Video
Format profile : Main@L3.2
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 19 min
Bit rate : 4 890 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 40.116 FPS
Original frame rate : 59.940 (60000/1001) FPS
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.132
Stream size : 4.76 GiB (94%)
5.08GB [www.dydao.com]Devils.On.The.Doorstep.2000.720p.x264.AC3-AHD
https://mega.nz/file/vH5kEJpR#pUUqLukWWyWcIBk9TtHgQW3uRxaoLO1KdXPbnCEGc2E
