lyglay1991
求助:AVS下BalanceBorders在VS里该怎么写
2017-08-14 22:09
如题,想知道AVS下BalanceBorders在VS里该怎么写,求助
Muonium
Re: 求助:AVS下BalanceBorders在VS里该怎么写
2017-08-15 1:53
2017/8/17更新:合并 MakeDiff / MergeDiff / Expr 组合,优化下性能
2017/8/18更新:收到报错, 参考 fdar0536的版本 把 CropAbs 都改成了 CropRel
BalanceBorders.py:
import vapoursynth as vs import mvsfunc as mvf import math # BalanceBorders by PL — [2009.09.25] v0.2 # Port by Muonium 2017/8/14 # Source: https://www.dropbox.com/s/v8fm6om7hm1dz0b/BalanceBorders.avs def scale(val, bits): return val * ((1 << bits) - 1) // 255 def TurnRight(clip): core = vs.get_core() return core.std.FlipVertical(clip).std.Transpose() def BalanceTopBorder(c, cTop, thresh, blur): core = vs.get_core() cWidth = c.width cHeight = c.height cTop = min(cTop, cHeight - 1) blurWidth = max(4, math.floor(cWidth / blur)) c2 = mvf.PointPower(c, 1, 1) #last = core.std.CropAbs(c2, cWidth * 2, 2, 0, cTop * 2) last = core.std.CropRel(c2, 0, 0, cTop*2, (cHeight - cTop - 1) * 2) last = core.resize.Point(last, cWidth * 2, cTop * 2) last = core.resize.Bilinear(last, blurWidth * 2, cTop * 2) last = core.std.Convolution(last, [1, 1, 1], mode='h') last = core.resize.Bilinear(last, cWidth * 2, cTop * 2) referenceBlur = last original = core.std.CropRel(c2, 0, 0, 0, (cHeight - cTop) * 2) last = original last = core.resize.Bilinear(last, blurWidth * 2, cTop * 2) last = core.std.Convolution(last, [1, 1, 1], mode='h') last = core.resize.Bilinear(last, cWidth * 2, cTop * 2) originalBlur = last """ balanced = core.std.Expr([original, originalBlur, referenceBlur], ['z y - x +']) difference = core.std.MakeDiff(balanced, original) tp = scale(128 + thresh, c.format.bits_per_sample) tm = scale(128 - thresh, c.format.bits_per_sample) difference = core.std.Expr([difference], ['x {tp} min {tm} max'.format(tp=tp, tm=tm)]) last = core.std.MergeDiff(original, difference) """ tp = scale(thresh, c.format.bits_per_sample) tm = -tp last = core.std.Expr([original, originalBlur, referenceBlur], ['z y - {tp} min {tm} max x +'.format(tp=tp, tm=tm)]) return core.std.StackVertical([last, core.std.CropRel(c2, 0, 0, cTop*2, 0)]).resize.Point(cWidth, cHeight) def BalanceBorders(c, cTop=0, cBottom=0, cLeft=0, cRight=0, thresh=128, blur=999): core = vs.get_core() last = c if cTop > 0: last = BalanceTopBorder(last, cTop, thresh, blur) last = TurnRight(last) if cLeft > 0: last = BalanceTopBorder(last, cLeft, thresh, blur) last = TurnRight(last) if cBottom > 0: last = BalanceTopBorder(last, cBottom, thresh, blur) last = TurnRight(last) if cRight > 0: last = BalanceTopBorder(last, cRight, thresh, blur) last = TurnRight(last) return last
删掉了 avsi 中对色彩空间的限制。自己注意 blur 和 thresh 两个参数大于0就好,懒得写范围检查了。
thresh 会自动根据视频的位深进行调整,范围和 avsi 中的一样。
俄文文档就不翻译了 {:husky}
这论坛的Codebox是怎么用的?
上次由 Muonium 在 2017-08-20 23:43,总共编辑 5 次。
被噪点番支配的噩梦
被Waifu2x吊打的噩梦
不会写代码不会写脚本的我连咸鱼都不如了orz
eedi3好慢啊…………
为什么某SSIM的计算值大于1……
被一个月前自己写的脚本吊打,很爽
CropAbs上也能掉坑……
不要乱搞什么对数亮度作图…
魔幻炼丹主义
lyglay1991
2017-08-15 19:47
Muonium 写了:BalanceBorders.py:
import vapoursynth as vs import mvsfunc as mvf import math # BalanceBorders by PL — [2009.09.25] v0.2 # Port by Muonium 2017/8/14 # Source: https://www.dropbox.com/s/v8fm6om7hm1dz0b/BalanceBorders.avs def scale(val, bits): return val * ((1 << bits) - 1) // 255 def TurnRight(clip): core = vs.get_core() return core.std.FlipVertical(clip).std.Transpose() def BalanceTopBorder(c, cTop, thresh, blur): core = vs.get_core() cWidth = c.width cHeight = c.height cTop = min(cTop, cHeight - 1) blurWidth = max(4, math.floor(cWidth / blur)) c2 = mvf.PointPower(c, 1, 1) last = core.std.CropAbs(c2, cWidth * 2, 2, 0, cTop * 2) last = core.resize.Point(last, cWidth * 2, cTop * 2) last = core.resize.Bilinear(last, blurWidth * 2, cTop * 2) last = core.std.Convolution(last, [1, 1, 1], mode='h') last = core.resize.Bilinear(last, cWidth * 2, cTop * 2) referenceBlur = last original = core.std.CropAbs(c2, cWidth * 2, cTop * 2, 0, 0) last = original last = core.resize.Bilinear(last, blurWidth * 2, cTop * 2) last = core.std.Convolution(last, [1, 1, 1], mode='h') last = core.resize.Bilinear(last, cWidth * 2, cTop * 2) originalBlur = last balanced = core.std.Expr([original, originalBlur, referenceBlur], ['z y - x +']) difference = core.std.MakeDiff(balanced, original) tp = scale(128 + thresh, c.format.bits_per_sample) tm = scale(128 - thresh, c.format.bits_per_sample) difference = core.std.Expr([difference], ['x {tp} min {tm} max'.format(tp=tp, tm=tm)]) last = core.std.MergeDiff(original, difference) return core.std.StackVertical([last, core.std.CropAbs(c2, cWidth * 2, (cHeight - cTop) * 2, 0, cTop * 2)]).resize.Point(cWidth, cHeight) def BalanceBorders(c, cTop=0, cBottom=0, cLeft=0, cRight=0, thresh=128, blur=999): core = vs.get_core() last = c if cTop > 0: last = BalanceTopBorder(last, cTop, thresh, blur) last = TurnRight(last) if cLeft > 0: last = BalanceTopBorder(last, cLeft, thresh, blur) last = TurnRight(last) if cBottom > 0: last = BalanceTopBorder(last, cBottom, thresh, blur) last = TurnRight(last) if cRight > 0: last = BalanceTopBorder(last, cRight, thresh, blur) last = TurnRight(last) return last
俄文文档就不翻译了 {:husky}
这论坛的Codebox是怎么用的?
感谢移植,试了一下,预览效果不错,不知压制怎么样了,期待中
