BM3D-r7 | BM3D和V-BM3D降噪算法的VS滤镜实现
Source & Readme
Binary: GitHub | NMM
After over a month's effort, it's finally completed.
Including the 2D(image) denoising filter BM3D and the 3D(video) denoising filter V-BM3D.
The computational complexity of this denoising algorithm is fairly high, thus it's very slow.
Moreover, the memory consumption of V-BM3D is very high. Since for each current frame, multiple frames are requested, and the filtering result is also aggregated to those frames.
包括2D(图像)降噪算法BM3D的实现,以及3D(视频)降噪算法V-BM3D的实现。
建议使用mvsfunc中的BM3D函数,使用更方便简单:
import mvsfunc as mvf core.max_cache_size = 4000 # Set a big enough cache size. For V-BM3D, you may need 8000 or even more (according to resolution and radius) # Any input format clip = mvf.BM3D(clip, sigma=[3,3,3], radius1=0) # radius1=0 for BM3D, radius1>0 for V-BM3D # Same as input format
上次由 mawen1250 在 2016-08-16 13:43,总共编辑 6 次。
Re: BM3D-r3 最佳的降噪算法之一,BM3D和V-BM3D的VS滤镜实现
Update r3
Fixed a stupid mistake that the order of applying DCT and IDCT is reversed (it should be DCT->filter->IDCT), which leads to over-filtering in fine structures and produces artifacts such as blocking, ringing and desaturation.
Now it actually filters as expected.
之前居然把DCT和IDCT的顺序搞反了(FFTW里的FFTW_REDFT10和FFTW_REDFT01被我弄反了,明明还看了好多次的说……),这下处理结果终于类似于官方MATLAB版的结果了。
vempx
辛苦了
这几天处理的片子都没有noise,等遇到需要降噪的片子我就试试你的这个滤镜!
在提问前还请仔细查阅公告帖以及各版置顶帖
相信置顶中也许会有您需要的内容
~My Blog~
贴一些我这儿的测试结果,CPU有点弱(像i7 E3之类的大概有我的2倍速度)。
AMD X4 635 @ 2.9GHz 8GB x 2 Windows 7 x64 VapourSynth r27 x64 BM3D r3 x64 1920x1080 YUV420P8 input convert to 16bit OPP to process 16bit RGB output request 200 frames threads=4 max_cache_size=10000 VBasic+VFinal, profile="fast", process all channels radius fps 1 0.44 2 0.33 3 0.24 4 memory boom! VBasic+VFinal, profile="fast", process Y only in GRAY color family radius fps 1 0.62 2 0.45 3 0.35 4 0.29
基本上处理1080p的YUV的话,radius=1的V-BM3D至少需要大概5GB内存,速度会比默认参数下的BM3D还快一些(因为V-BM3D一些参数低),radius=4就完全爆内存了。处理Gray的内存消耗就低了不少(理论上应该只有1/3)。
vempx
这个速度……太感人了……
相信置顶中也许会有您需要的内容
~My Blog~
digimoon
不知道为啥直接loadplugin或者将dll扔到vs的plugin目录里都提示没有这个namespace,libfftw3f-3已经在path里了难道还需要装其他什么运行库吗?
win10 x64,vs r28 x64
{:cat_15} win10逗逼了似乎是没有载入,重启一下后正常了
lsy17096535
联系: Skype
斑竹你好 能发个bm3d处理的脚本吗?我这里一直报错,最近做压片,想提高一下亮度,并且降噪,谢谢啦。
