General
Complete name : M:\Live\日本8级大地震.1080i HDTV MPEG2-CHDTV.ts
Format : MPEG-TS
File size : 8.38 GiB
Duration : 1h 13mn
Start time : UTC 2011-03-11 15:25:19
End time : UTC 2011-03-11 16:38:59
Overall bit rate : 16.3 Mbps
Network name : 4XEl9-0h#0
Video #1
Menu ID : 1025 (0x401) / 1024 (0x400)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Codec ID : 2
Duration : 1h 13mn
Bit rate mode : Variable
Nominal bit rate : 24.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.515
Video #2
Menu ID : 1408 (0x580)
Format profile : Baseline@L1.2
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : 27
Duration : 1h 13mn
Bit rate mode : Constant
Nominal bit rate : 200 Kbps
Width : 320 pixels
Height : 180 pixels
Frame rate mode : Variable
Bit depth : 8 bits
Scan type : Progressive
Audio #1
Format : AAC
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 1h 13mn
Bit rate : 141 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -115ms
Stream size : 74.3 MiB (1%)
Audio #2
Format : AAC
Format profile : HE-AAC / LC
Muxing mode : ADTS
Codec ID : 15
Duration : 1h 13mn
Bit rate : 48.0 Kbps
Sampling rate : 48.0 KHz / 24.0 KHz
Delay relative to video : -162ms
Stream size : 25.3 MiB (0%)
症状如下:在MPC-HC下,只能用Arcsoft的分离器分离,其它要么是干脆崩溃,要么直接把第二个AVC的那个轨播出来了。但是在Arcsoft分离下,无法切换……而且音频居然只能用Microsoft DTV-DVD Audio Decoder来解码……
用TMT5播放,视频正常,音频呢就是变成第三个和第四个音轨的混合体了。
各位大大帮帮我吧……
