Holy 写了:你還是截個圖來看吧……最好也把 MediaInfo 一併附上了。
請看
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 206 MiB
Duration : 25mn 40s
Overall bit rate : 1 124 Kbps
Encoded date : UTC 2014-01-21 00:37:59
Tagged date : UTC 2014-01-21 00:37:59
Writing application : qaac 2.18, CoreAudioToolbox 7.9.7.8, AAC-LC Encoder, TVBR q100, Quality 96
Video
Format profile : High 10@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 10 frames
Codec ID : avc1
Duration : 25mn 40s
Bit rate : 1 005 Kbps
Maximum bit rate : 4 787 Kbps
Width : 960 pixels
Height : 720 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.061
Stream size : 185 MiB (89%)
Writing library : x264 core 138 r2359+704+48 3f879a0 tMod [10-bit@all X86_64]
Encoding settings : cabac=1 / ref=10 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / fade_compensate=0.00 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.7086 / qcomp=0.60 / qpmin=0:0:0 / qpmax=81:81:81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 25mn 40s
Bit rate mode : Variable
Bit rate : 115 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 21.1 MiB (10%)
